Is anything salvageable from my motor?
Old Jun 1, 2014 | 09:37 PM
EvoRinga's Avatar
So unfortunately a few months ago I was driving and lost my oil drain plug. By the time I noticed the oil light I'm afraid it was too late. The car shut off on me and had to be towed. I've been so busy I have not had the time to touch anything on the car. Sadly I had just spent a lot of money on a built shortblock and was only able to drive the car for 3 hours after the tune on it. I know the turbo was starved and will need a rebuild but I'm curious to what I'll be able to reuse in the next rebuild as far as pistons rods crank and the whole head assembly.. Thanks
Old Jun 1, 2014 | 09:41 PM
2slow4g63's Avatar
sucks to hear what happen but if you need one i have one for sale
Old Jun 1, 2014 | 10:16 PM
LetsGetThisDone's Avatar
Rods MIGHT be salvageable. Highly like everything will be junk since it shut itself off. Only way to know is to tear it down...
Old Jun 1, 2014 | 10:32 PM
essej's Avatar
Dang what a slump! Something that simple can cause fatal damage.
Old Jun 2, 2014 | 11:56 AM
slowsrt4:('s Avatar
the block should be good with a honing maybe replace a sleeve
Old Jun 2, 2014 | 12:53 PM
That can depend on if the crank ate through the unoiled thrust washer and ate up the block. Also, cylinders can get pretty torn up when run without oil.
Old Jun 2, 2014 | 10:49 PM
94AWDcoupe's Avatar
block will be fine as well as pistons. crank will be toast. rods most likely toast as well.
Old Jun 5, 2014 | 11:36 PM
ReidFletcher's Avatar
Thoroughly wash/replace anything that touches oil. Have a machine shop wash the head, buy a new oil cooler, buy new oil pump, send turbo in to be inspected. Rebuilding an engine that spun a bearing is expensive and more labor intensive. It's cheaper to spend more money now and go through everything than to do this all over again.
BeastYamin
Sep 15, 2015 06:45 AM
kaj
Sep 6, 2015 02:13 PM
MP Evo
Dec 28, 2014 05:04 PM
phrequenc
Apr 18, 2012 01:29 PM
20gmr
22
Oct 31, 2011 01:35 PM
