Engine oil help
Old Jun 28, 2014 | 12:58 PM
Roberto774's Avatar
Engine oil help
Hi everyone. Yes, another thread about oils LOL but i need some info here.
im on plans to change mi engone oil, right now im using VR1 20w50 but is getting a little hard to find it (i live in Venezuela) so right now is a easy for me to find here Motul 300v Power (5w-40) and LeMans (20w-60) but i cant find good info about this oil in the forum.
A good shop here in venezuela use in his evo's the LeMans series but that 20w-60 is not to much?? We have temp around 86F-95F all the year so wich one should be better??
My evo has a fully build engine!
Thanks a lot!
Old Jun 28, 2014 | 01:11 PM
Cal City Evo's Avatar
20W60 WOW!!! I have never heard of that before. You are bordering on gear oil weight. I have never heard of running this heavy weight of oil in the engine.
Mind you I'm just another with an opinion that may not be what you need but I have never run anything more than 50W in the crank case. That just seems to be way too much but what do I know? Right now I run 10W 40 in mine no problems. You shouldn't need the heavy weight unless your motor is junk even then it's too thick for my likes.
I see you are in Venezuela also. I wouldn't think that matters much of anything. Just how built is your engine also?
Good luck with your choice.
Old Jun 28, 2014 | 01:12 PM
Danged double post!!!!
Old Jun 28, 2014 | 01:22 PM
Roberto774's Avatar
Me engine was build with factory specs (i build it with a brand new block) so all is factory forged? lol. Also my engine only have 8k miles since i build it
And yes thats the reason why im ask... it seem so much, maybe if my engine was build for track ONLY but no... some road racing and normal drive for me old evo 5 lol
Old Jun 28, 2014 | 01:25 PM
Faisalm's Avatar
Use a 10w30 if you're still stock block, you'll be fine.
oscarquinones's Avatar
how you doing. I am from Puerto rico and is always above 90 and getting to 105 but in my personal opinion that is t much. 10w 30 it will work fantastic and synthetic.
Old Jun 28, 2014 | 01:30 PM
Roberto774's Avatar
No, im not stock block is a fully build but with factory clearance.....
Yes in some place here in Vzla we have those temp to, but where i live let's say is a little more cold? hahaha...
Old Jun 28, 2014 | 01:34 PM
Roberto774's Avatar
And yes i know 10w30 should be the best but her we dont have to much options so this motul is THE BEST i can find here THE BEST, for that reason im ask to all here
Old Jun 28, 2014 | 01:43 PM
if you going to put it anyways just do it.
Old Jun 28, 2014 | 01:49 PM
Roberto774's Avatar
Lol for sure, the motul 5w40 should be the chose one so
fastboat4life
Aug 6, 2016 08:52 AM
audiofan
May 20, 2015 10:55 AM
Chino051
For Sale - Wheels / Tires
Apr 16, 2015 10:27 AM
Lodus
Nov 8, 2014 11:30 AM
WheelDude.com
Mar 3, 2014 11:04 AM
