Gsc zero tick lifters problem
Old Jul 19, 2014 | 02:13 PM
opie's Avatar
Ok I need some help.i changed out my stock lifters for a set of gsc no tick lifters and now the valves stay slightly open. This is on my Evo 8 with an Ams race head and tomei cams. Has anyone else had a problem with the gsc lifters?
Old Jul 19, 2014 | 03:06 PM
1slow93turbo's Avatar
A friend had the same problem on his car so I sent him oem lifters and it fixed everything. I haven't had time to research but iirc they are taller for some reason. OEM is all I've ever used on 800+ hp 4g63's.
Old Jul 19, 2014 | 03:08 PM
https://www.evolutionm.net/forums/ev...mpression.html
Old Jul 19, 2014 | 04:31 PM
opie's Avatar
Yea even fully bleed of oil they still push the valves open. I guess I need to find some stock lifters.
Old Jul 21, 2014 | 08:15 PM
Sir2egk's Avatar
You need to bleed them correctly.
Old Jul 22, 2014 | 03:23 AM
opie's Avatar
They are bleed correctly. I talked to Gsc yesterday and they informed me that I need to trim down my valve stem for them to fit. I'm not going to do that so the oem are going back in.
Old Jul 22, 2014 | 04:32 AM
meckert's Avatar
read the link provided first---then if you look around there are some larger bore stock 4g63 lifters out there that work fine as well. I used them on a cam install they worked great --that was some years ago
Howulikemyevo
40
Sep 29, 2021 04:39 PM
Howulikemyevo
Jul 18, 2016 11:47 AM
navr11
Mar 6, 2016 07:06 PM
itsmrrizz2you
14
Jul 21, 2014 08:19 PM
Evolution 8 MR
Dec 1, 2012 11:53 AM
