To use 4G64 OEM cran or not to???
Old Sep 30, 2014 | 06:27 AM
CT9A PR's Avatar
Was talking to a few people and they said its not reliable. Others say they have made 700-900 WHP on them with out issues. What would EvoM and reputable shops advice be?
Does it depend on how light the rods are we are thinking about using aluminum rods for this R&R with HD Piston pins.
Not sure if to use 156mm or 162mm though.
Old Sep 30, 2014 | 06:47 AM
evolve_VIII's Avatar
I have used plenty of 64 cranks with no failures at 400-650 whp. Which is closer to 800 flywheel horse power.
An addition that I do to my cranks is lighten them up. I have part of the counter weights cut off then the crank polished and balanced. After that it is Nitrided. They key to this is to NOT knife edge the crank. The weights are designed to absorb harmonics from the rotating assembly. If you make when slimmer, you will remove the mechanical properties of the crank that assist in removing the harmonics.
boostawd16
Nov 18, 2013 07:46 PM
djikonatx
60
Sep 13, 2013 11:08 AM
mrboost05
Mar 6, 2013 09:58 AM
bostonhatcher
26
Oct 10, 2012 08:33 AM
djikonatx
164
Jun 20, 2012 08:02 AM
