DSS carbon fiber driveshaft on a evo for those interested in install pictures
It can be easily removed on these cars. I forget the socket size, i believe 26mm. Its held on by about 120tq.
Since the evo uses a solid spacer and shim, there is no crush collar to be worrying about like some other rear diff's.
PM me for that please.
I don't think so. There is most likely a reason they have it for AYC and non AYC. If you want I can ask to verify though.
Also -40F is ok for the carbon shaft. DSS said the cold temps will not affect it. Hot temps will though. After a certain temp (very hot), the glue that holds the pieces onto the carbon fiber shaft can fail. I believe its something like 400F+ temps though.
I did not. Ya that's how I feel about it. They just broom and explode pretty much.
It seems like a loop wouldn't be to difficult though. You could maybe use the existing studs from the one missing carrier bearing location to attach it.
Why did you choose this heavier 2 piece CF DSS over the lighter 1 piece PST CF DS????
Cheaper and lighter.
http://pstds.com/shop/all-carbon-fib...er-driveshaft/
Pics installed on Evo 8
https://www.evolutionm.net/forums/ev...installed.html
Anyone looking to use the 1 piece carbon I highly recommend stock mounts WITH harder bushings. Do not get avid mounts.
Other then that this thing has been awesome.
