4G64's, pushing water common?
Hey guys in the process of having my 4G64 bottom end o-ringed with a graphite gasket, just wondering at what power figure your non-o-ringed block has started to have the head lift and start pushing water, as ive heard this is a common problem with 64's block. Any tips you guys have to seal the head better?
Any particular headstuds or head gasket?
Cheers Guys
Cheers Guys
I take it that's on E85. Any unusual precautionary prep other than decking the block and head? No o-ring right?
Also, I've been curious about those head gaskets by JE. Why did you choose it? In for learning.
A quality set of head studs (H11, Age 625 or L19) flat smooth finish (on head and block) and a proper Torque procedure should do the trick.
JE is good, Cosworth is great with O-ring, or OEM MLS. I don't like the cometic, never have never will
Don't forget to re torque after 50-100 miles.
I chose it because Wiseco mislabeled their pistons on the 4G64 application. The head volume is incorrect on the spec sheet causing a bump in compression. I did some research on JE because they make the thickest gasket for the 4G64 to lower the compression. They look like quality parts and I watched all the videos they had on them. There were not many reviews on here so I figured I would try it out for myself. It holds up great. No complaints here. It is a quality gasket and it is pretty cheap. I think it was 80ish shipped. Its fully rubber coated like the OEM one.
I did not deck the head and block. The block had low miles on it so I used WD40 and 2000 grit sand paper just to refinish the surface on both the head and block. I sprayed the gasket with copper spray and put it together.
It does not have o-rings.
I usually do 30, 70, 100. Then retorque after a few heat cycles.
2.4LR with 10:1 manley pistons and Flat Out HG no ring. 480 on 90 pump at 28, 616 on e85 at 36psi.
Used a piece of glass and 400 sandpaper on the block and head to smooth it out. No problems.
Your static compression ratio doesn't matter.
How much boost the turbo makes doesn't matter.
All that matters where the head gasket sealing surface is concerned is torque (pressure) and hp (heat).
These studs are 25% overtorqued and probably close to yield (failure). FYI
The 4G64 block is more prone to issues despite this, at least partially due to its thinner cylinder wall thickness.
), 30 psi 600whp, holding strong. I aim to up the boost here soon, so we will see I guess
