Evo 8 Rattling from Head/Valve Cover Area During Idle and Decleration
Yes, this is another one of those "Weird Evo Noises" threads. Obviously, I'm just looking for a little help and some suggestions here.
I took the Evo out this afternoon, and I was going through a drive-thru I noticed the car making a little more noise than normal. It basically sounds like something rattling around under the valve cover. The sound is especially noticeable at idle and it also gets pretty loud when I let my foot off the gas while driving. It kind of sounds like clutch chatter but I know it's not that because it does it with and without the clutch engaged. Other than the noise, the car runs and drives just like it always has.
Here is a video:
https://plus.google.com/photos/yourp...08629056144064
My mods are: FIC 1250 injectors, Full TBE with test pipe, MAP O2 dump, and speed density tune
Let me know if you guys have any thoughts on this. Thanks!
Here is a video:
Bump. Did some troubleshooting last night and noticed that I don't really hear the noise when the car first starts up. I start hearing it after the car has been running for about 5-10 seconds and it starts out quieter and then gets louder. Drove the car this morning and it drove fine but still sounded the same after driving it for about 45 minutes. It has recently gotten a lot colder here. Could that cause the injectors to be louder or could it be something else? It definitely sounds louder around the back of the head/injector area.
A little update: I noticed tonight that RPM doesn't seem to affect the noise. However, it does get very loud and noticeable when engine braking above 4K RPMs.
Your probably hearing tob rattle from your clutch, try cruising and just letting off the gas and coasting in 4th gear or 5. If it rattles while coasting down its definitely TOB rattle, they also rattle at idle try pushing the clutch in when its doing it if it silences it there's your noise.
Just wanted to update this and let everyone know what the issue was. Turns out it was my alternator. Not sure what exactly was going that made it sound this way but it eventually seized up on me while I was driving the car about two weeks ago. Had the alternator replaced and everything is good to go now.
FathouseFab
18
Apr 18, 2013 10:33 AM
yitzac1990
Lancer Engine Tech
Feb 25, 2010 04:08 PM
StevenStarke
Nov 14, 2007 06:26 AM
nine4surfah
Feb 25, 2004 08:39 AM
