Fp red not barley spooling.
Old Jan 9, 2015 | 09:45 AM
evole97's Avatar
This morning i took my car for a run and i did a pull. I could hear my wastegate open but car isnt going anywhere. the turbo doesnt spool til 3.5k can the turbo be breaking down? i checked all lines and all pips and clamps are tight.
Old Jan 9, 2015 | 09:49 AM
LetsGetThisDone's Avatar
fp red spooling at 3500 sounds pretty awesome IMO. What rpm do you hear the waste gate opening at?
Old Jan 9, 2015 | 09:56 AM
e_kobz's Avatar
How much preload is on the WGA?
Old Jan 9, 2015 | 10:02 AM
Ev0ikon's Avatar
No Kidding!
Old Jan 10, 2015 | 02:26 AM
slvrevo84's Avatar
is it holding boost?
Old Jan 10, 2015 | 02:30 AM
slvrevo84's Avatar
if none than maybe your wastegate is stuck open??
Old Jan 19, 2015 | 05:18 PM
evole97's Avatar
my guage shows i am only pushing 15psi and my car is tuned at 26psi so there is a 11psi leak
Old Jan 20, 2015 | 02:19 AM
wickedep's Avatar
check your spring/diaphram on the waste gate bro.
Old Jan 20, 2015 | 07:29 AM
llDemonll's Avatar
boost leak test.
everything else you do until that's been done is a moot point and a waste of time
Old Jan 20, 2015 | 07:53 AM
Evolution7GSR's Avatar
is it a newer red or older? how many miles are on it? if the boost leak comes up with nothing look into the wastgate and flapper. I had a green and the flapper eventually fell off causing a similar sounding problem.
Old Jan 21, 2015 | 03:31 AM
sparky's Avatar
OP: Are you in NorCal?
Old Jan 22, 2015 | 07:34 AM
sparky's Avatar
What WG is fitted to the turbo? Also, as "letsgetthisdone" asked, at what engine RPM and at what boost level are you hearing the wastegate flapper valve crack open?
Old Jan 22, 2015 | 08:01 AM
lonestarr20's Avatar
1.Put something in front of the radiator so you dont damge the fins
2.Disconnect the wastegate arm from
The hotside of the turbo
3.Pull on the wastegate arm, if it is difficult then it is NOT the wastegate
4. Check your manifold to turbo gasket, and your turbo to o2 gasket
5. Boost leak test
6. I HATE TO SAY IT, YOU MAY HAVE A CRACKED HOTSIDE.
I hope this helps..
One more test, pull all the lines off the wastegate and turbo outlet pipe.
Take a spin BE CAREFUL IT SHOULD OVER BOOST
I REPEAT BE CAREFUL
Then you'll know if the wastegate is working properly
I know because I just went down this road,building boost wouldn't go past 11psi, I had a cracked hotside, replace gaskets, and new hotside, VOILA !!!
Back in the game, let me know if you need help Im in LA, take care..
Old Jan 22, 2015 | 11:42 AM
sparky's Avatar
Originally Posted by lonestarr20
....2.Disconnect the wastegate arm fromThe hotside of the turbo...3.Pull on the wastegate arm, if it is difficult then it is NOT the wastegate...
This is a good test. Although it is not necessary to disconnect anything to pull on the actuator rod. At least, I never do. Just remove the manifold heat shield first.
Old Jan 22, 2015 | 04:30 PM
I forgot that step, thanks sparky
KarmaSRT
10
Apr 11, 2013 11:35 AM
john ho
16
Jan 19, 2013 02:27 PM
hiner005
Aug 30, 2012 11:17 PM
xspsi4
Jul 31, 2010 09:45 AM
myblk03evo
May 9, 2005 04:20 PM
