Need part # for Fuel Pump Kit for EVO 8
Old Mar 16, 2004 | 04:47 PM
italianowrx's Avatar
For the walbro Kit, does anyone know what the part number for the Pump Kit is?
CZ
Old Mar 16, 2004 | 05:00 PM
bishiboy's Avatar
The pump itself is a GSS342. You don't need the kit. I just installed mine in about 20min.
Thanks Ninos!
Old Mar 17, 2004 | 03:22 PM
ev8sive's Avatar
Bishiboy can you do a little how to on what to keep/remove for the fuel pump install from Nino... I too don't have any of the "kit" that I thought was supposed to come with it like the Evomoto install has.... I was concerned about re-using some of the parts and the filter.
Old Mar 17, 2004 | 09:50 PM
Zeus's Avatar
I used a GS342 from an Acura... I reused all the OE EVO parts less the pump alone... no issues, direct fit.
Old Mar 18, 2004 | 08:05 AM
bishiboy's Avatar
No concern reuseing parts. Unless you break something there isn't anything that needs replacing.
Once you get the pump assembly out of the car, flip it over, (it will leak some fuel), carefully pry the 3 plastic clips that holds the pump in the assembly, then carefully remove the small locking ring (don't know the name of it) that hold the screen filter to the pump, the screen filter pull straight up and off. Once removed, pull out on pump, unplug the wires, take the plastic ring off the pump outlet, (if the rubber seal came out, put it back into the assembly).
Now take the plastic ring (that came off the outlet) and put on new pump, assemble everything in reverse. Be sure to put the little rubber spacer back in between pump and pump retaining cup (the thing with the 3 plastic clips).
Put it back in the car and your done.
Vivid Racing has some pics if you need them.
This is very easy and only took me 20-25 mins.
Good luck
Alchem1st
Oct 2, 2017 06:42 AM
boostedlife
May 19, 2016 08:01 AM
srphoenix
Apr 10, 2014 08:07 AM
booster9
South Region
Jan 9, 2010 05:48 PM
RaysEvoX
Jun 27, 2009 03:21 AM
