Too Much Boost, Solenoid stays open
Hello All,
I had just replaced my wastegate actuator due to the other one going bad, but now I do not see the waste gate arm ever open under normal operation. I can put the rated pressure through the line to open it but it appears the OEM boost controller solenoid is staying open.
I do not have a manual boost controller, it is setup to be controlled by the ECU. While the car is running I can simulate the solenoid shutting by plugging the line and see the arm move as boost builds.
I have also used evoscan to test the solenoid and it appears to be working correctly. I am new to turbos and not really sure what sensor is telling the ECU to close the solenoid to let off boost.
Any help or explanation would be much appreciated. Thanks!
Hello All,
First, the waste gate solenoid remains shut until target boost or load is reached and then it opens to send boost to the actuator to open the wastegate. It sounds like it's working properly to me. Go out and log a pull..
My03evo
15
Feb 9, 2011 07:37 AM
mega-z
13
Mar 13, 2009 01:05 PM
