Car goes lean when its warmed up like 14-15 AFR at WOT
Car drives fine and spools hard.
Its pretty much a stock evo with TBE and FP Intake.
Car when I beat on it after 20 minutes goes lean!
It will be running 11.1 AFR till around 7000 RPM then all of the sudden goes lean. I did a boost leak on it and found out the bottom seals of the injectors were bad. If it isnt this what could it be?
Car had a meth kit and it was taken off when I put it back to almost stock form.
Has 560cc injectors with no scam so its not a scaling or latency issue. Its such a piece when its warmed up. When its cool though it runs very hard!
Is the fuel pump getting hot? has a walbro on it. Sorry no FPR its a stock evo dont see the point.
Tanman1986
24
Feb 26, 2017 07:55 PM
Hotsauce101
Jul 23, 2015 11:57 AM
