How bad did I mess this up?
true. but you should do the research before just messing with stuff. i never do a major job without the service manual (you can download it for free). even though i'm pretty familiar with cars, especially mine, i tend to forget little things.
having your cams so far off (twice) is really bad and can end up costing you quite a bit. hopefully not..
but that's a really important job to attempt without knowing what you are doing.
In all reality, IF it bent valves, He can replace the few that bent (it will likely only be one cylinder if anything happened) and then get the whole head rebuilt (fresh valve job and seals, surfaced) for less then $300. So, it's not an end of the world mistake. Doing the work himself he has saved a good bit more than that on labor, and he's learning.
OK in all reality then if there was no binding or even sound of the valves touching. There's a chance I didn't bend any of them. I only turned it by hand. After I read this I loosened the belt turned then crank counter clockwise quarter of a turn and turned the cam gears by hand and they fell into place.
I'm glad it looks like everything is OK.
