evo 6 not building boost
Old Jan 25, 2016 | 03:10 PM
abrar's Avatar
hi guys
im having probs with my evo 6 turbo hardly building any boost i was getting around 0.2 bar from 3rd gear pull from 3k revs all the way up to 7k revs.i had the system smoke tested and there were no leaks.
the actuator is not moving when reving.would tht only cause overboosting or could it cause it to under boost also ?
any help would be much appreciated
Old Jan 25, 2016 | 03:43 PM
RS200's Avatar
The wastegate flapper could be stuck open, but it would be obvious. On my Evo, the arm fell off the flapper lever and basically did what you describe.
Old Jan 25, 2016 | 06:37 PM
wickedep's Avatar
if there are no exhaust leaks pre-turbo (gaskets), fmic pipes or blow off..then check actuator. if this is ok too then you may need to pull out turbo and inspect it.
Old Jan 25, 2016 | 09:34 PM
abrar's Avatar
Could wastegate be stick open without the arm having fallen off.is that possible?
Old Jan 25, 2016 | 11:15 PM
roni4g63's Avatar
how about your WGDC tables in ecuflash? if they are all set to 0 (fir whatever reason) it could cause this
galantman03
43
Feb 5, 2017 09:54 PM
evokid511
17
Feb 17, 2011 05:13 PM
neodestroyer
59
Apr 9, 2009 09:42 PM
Blue Evo 8
May 22, 2006 11:16 PM
