Diaqueen (now MZ320345) SAE90 LSD Oil Discussion
#76
Group 5 ester based oils (Motul & Redline) are the best lubricant types available. They also tend to have a superior additive package for anti-wear protection. Mineral types cannot compare. The cold viscosity is irrelevant because when your driving your car it wont stay cold it will come up to "operating temp" and thin out anyway. You only need to worry about the second number 90 in 75w90.
#78
All of the reasons for group 5 being better for engine oil are the same reasons why it is better for gear oil.. Better detergency, film strength, high heat & high shear stability, lubricity and the clinging effect that esters have on metal surfaces. The fact that redline and motul also use a ton of zddp and moly additives is a bonus.
#79
Thanks
#80
Hey Kyoo. quick question, you say you use 75W90 in the T-case and Rear Differential, My drivetrain with fully build by Shep. I am going to use 75W90 in the T-case and rear differential, what would you recommend for transmission fluid? Where I live it goes down to -15 if that makes any difference. MT-85 75W85 GL4 OR MT-90 75W90 GL-4?
Thanks
Thanks
SoSoEVO (Nov 20, 2018)
#83
Ahhh ok so the trans needs gl4 and tcase/ rear diff used gl5?
Thanks in advance!
#84
I'm stock as far as power level goes...I read through the thread and standard redline gear oil slightly edges out the the Diaqueen with phosphorus and boron correct? So for just a weekend car with track days often do you recommend the thickness of the Diaqueen or would the standard redline be fine? I know you mention you auto x your car often but idk if the heat generated is the same as a longer road course.
Thanks in advance!
Thanks in advance!
trans needs GL4, either 75w90 for 5spd or 75w85 for 6spd
#85
i've run redline 75w90 with zero issue, on track and autox. i flush my fluid annually, which may be overkill though - regardless, i flush more frequently than most anyway. heat generated on road course is far, far higher.
https://www.redlineoil.com/gear-oil-...-transmissions
Update:
Never mind I found it under the "gear oil for diff" section.
#86
Sweet thanks man I appreciate it! Haha that's not overkill that's just proactive maintenance. Last question the gl5 redline I'm only seeing "ns". Is that what you use for the tcase and rear diff?
Update:
Update:
#89
GL4 Gear oil is for the TRANSMISSION. NOT the transfercase.
The tcase at minimum needs GL5 75w90. TRE recommends 80w140 GL5.
If you put GL4 fluid in the transfercase, you will wipe out the gear set in short order.
#90
right, it can be confusing because "trans"mission & "trans"fer case. GL4 in transmission, GL5 in transfer case and rear diff.
I did actually accidentally put GL4 into the t-case once, be careful as the bottles look identical. I flushed it out immediately for GL5. I also ran some lightweight shockproof in the t-case with no ill effect, but decided to roll with the GL5 after doing the test and seeing how closely redline's GL5 additives matched with DQ's.
