Stock frame turbo options
Old Feb 2, 2016 | 06:22 AM
STIU2SLO's Avatar
Originally Posted by Drsous
My issue is that I dont want to cut and weld anything. I'm just looking for a direct bolt on. Remove my stock turbo and bolt up the new one
I just purchased the new FP black SS housing, STM tuned inc makes the new dp, with recirc or 02 dump for $650 I believe and they make some damn good parts!
Old Feb 2, 2016 | 06:31 AM
IzzyRS's Avatar
They seem to have "limited run offers" on the MHI housings once or twice a year.
Trueeee
Old Feb 2, 2016 | 03:28 PM
Drsous's Avatar
Originally Posted by Merle
There is a new in the box BBK Full on here for sale and it is good for 500 on E85. I love mine fast spool and fun to drive. It is a direct bolt on
Was looking at that too, but I believe it's sold now.
Old Feb 2, 2016 | 03:37 PM
nemsin's Avatar
What stock frame turbo options do we have left?
What is your budget, hp goal, and intended use?
Old Feb 2, 2016 | 05:28 PM
Drsous's Avatar
2k for a turbo. I'm looking to achieve 400-500 awhp on a mustang dyno and 93 pump gas is a must. I don't want to run meth mix or e85. I have a br 2.0 lr built block with a built head cosworth m2 cams, gsc valves, springs, retainers. Picking up Id 1000cc injectors and 3.5 wide tank ets fmic. This car will be daily driven.
Old Feb 2, 2016 | 06:49 PM
Beaver2.0t's Avatar
Are you familiar of chris robbins with turbos-r-us?
Old Feb 2, 2016 | 10:52 PM
e_kobz's Avatar
You'll want something bigger than ID1000's if you're planning to run E85
Old Feb 3, 2016 | 03:44 AM
Drsous's Avatar
No I'm not. Please enlighten me sir. Any knowledge is better than none
Drsous's Avatar
I don't plan on running e85 or meth just straight pump gas.
Old Feb 3, 2016 | 05:16 AM
TrendSetter's Avatar
did you even read his post?
Old Feb 3, 2016 | 08:00 AM
e_kobz's Avatar
I misread it at first. ID1000's will be fine. But why ot going with some FIC 1120's. You literally just drop them in since they're low-z, they're cheaper, and they flow more (fyi ID1000's only flow around 900cc's).
Old Feb 3, 2016 | 10:12 AM
nemsin's Avatar
I would recommend a JB MHI FP Red, on sale for $1599 http://www.forcedperformance.net/mer...e=Lancer-Turbo
If you can swing $2250 for the turbo, I would say get a Blouch 1.0xtr http://www.maperformance.com/product...vo9-dom-1-0xtr
Old Feb 3, 2016 | 11:55 AM
Drsous's Avatar
Can you tell if there is any major spool difference and trasient power between the 2?
Old Feb 3, 2016 | 12:05 PM
nemsin's Avatar
Well the FP red flows about 60lb/min
While, MAP says the Blouch flow rates are as follows:
Dom 1.0XT and 1.0XTR flow 47-48lbs per min
Dom 2.0XTR flows 56-57lbs per min
https://www.evolutionm.net/forums/ev...ns-blouch.html
So maybe the 2.0XTR is a better comparison. That said, I have "heard" the 1.0XTR is essentially the same as a BBK full (when Blouch turbos were sold through CBRD). So 400-450whp is realistic on pump gas.
I have not seen any dyno charts of the 2.0XTR, but I would guess it gives up ~500rpm in spool for maybe 30-40 more whp up top.
For a DD 2.0 4G63, I would personally go with a 1.0XTR, but if you want to be closer to the high end on your 400-500whp goal, then go 2.0XTR.
Old Feb 3, 2016 | 03:45 PM
its pretty easy to bypass the resistor pack, was about 5 min of work when i did mine. i put in some of those asnu fic 1050s. theyre pretty nice. good clean idle and all that.
