I finally found a replacement turbo!!
Old Feb 22, 2016 | 11:20 AM
vmrevo9's Avatar
Veteran: Air Force
I have considered the BBK-B as a replacement as well as the 3076R. Truthfully the HPB-IX did not feel laggy at all. As I was filming the car from the outside and Ross did the pull my buddy who was the passenger at that moment told me that it broke all 4 loose. I'll see if i can get some more info on spool, etc.
Old Feb 22, 2016 | 11:30 AM
Erik@MIL.SPEC's Avatar
In the MLR thread, they said this spooled 200 to 300rpms sooner than an HTA Green.
Old Feb 22, 2016 | 11:51 AM
vmrevo9's Avatar
Veteran: Air Force
It didn't feel like it was laggy on the road. The test car is a built 2.0l with 9:1 compression ratio. It's a pump gas motor. I'm sure the head is ported and such and it also has a sheet metal intake. It pulled pretty good!
Old Feb 22, 2016 | 06:38 PM
e30_pilot's Avatar
That gear box doe!! So jealous.
Old Feb 28, 2016 | 04:27 AM
Torito_Evo's Avatar
I was the passenger on this pull and the car felt amazing, no lag at all.
Old Mar 6, 2016 | 02:08 PM
vmrevo9's Avatar
Veteran: Air Force
I should have this turbo on hand in about 2 weeks. Ill be ordering an invidia o2 housing and some misc gaskets for the turbo swap. Once i get it in ill see about retuning and a review.
Old Mar 6, 2016 | 07:24 PM
lv05evo's Avatar
Why not get a Tomei V.2 O2 housing and downpipe or similar? The O2 housing is 3" at the downpipe, invidia is 2.5".
Old Mar 6, 2016 | 08:40 PM
kaj's Avatar
kaj
My Ividia is 3" at the opening. I have another o2 housing that isn't, though.. i can't remember the name. It's one that was popular a few years ago. I'd still use it, if i could find a downpipe to match. I don't like how little room the Invidia part has to tighten the nuts and bolts. Getting to the nut in the elbow is pretty much impossible.
Old Mar 7, 2016 | 03:40 AM
kikiturbo's Avatar
just to give you an idea... we built this 3 inch straight trough DP and elbow for a hks 7460 build..
Old Mar 7, 2016 | 04:21 AM
vmrevo9's Avatar
Veteran: Air Force
Interesting I was under the impression that the invidia was larger than 2.5" at the downpipe side. I'll have to look into it.
I rather not replace my downpipe since I already have a 3" version
Old Apr 18, 2016 | 01:50 PM
vmrevo9's Avatar
Veteran: Air Force
So i recieved the new turbo today. Ill take some pics and post it up tomorrow. It will be a little bit before i install it and get it tuned.
This thing looks pretty damn nice and i cant wait to see what it'll do
Old Apr 19, 2016 | 01:12 PM
synmaster941's Avatar
Excelllent video, thanks mate!
Old Apr 19, 2016 | 02:16 PM
vmrevo9's Avatar
Veteran: Air Force
Pics
Old Apr 19, 2016 | 02:24 PM
Nice. Once these turbos get more prevalent, it will be interesting to compare the Ross Sport VD graphs to FP54 graphs.
Old Apr 19, 2016 | 02:28 PM
vmrevo9's Avatar
Veteran: Air Force
I can't wait to see the difference between them. According to Ross the specs are pretty close.
Since I'm on a stock block I'll have to keep it "safe" for now. Once I return stateside I'll be rebuilding the motor and trans and turn up the boost.
