STM Sealed Catch Can
Old Apr 1, 2016 | 09:50 AM
  #31
LetsGetThisDone's Avatar
Originally Posted by EvoIIIAj
What exactly makes the STM can so good to prevent the FP turbos pushing oil?
Because on throttle, both port from the valve cover are being vented into the turbo inlet. Off throttle, it has a PCV valve that opens and allows the vacuum from the intake manifold to keep crank case pressure under control.
Old Apr 1, 2016 | 11:46 AM
  #32
GrabbinGears's Avatar
Originally Posted by WickedRSEvo
Grabbingears-Are you running e85? I don't see a whole lot of oil in either can, although there is some, but definitely enough water that I wouldn't not run a catch can. This was my first full tank of e85, and I have been monitoring the car closely. I'll fill up with 93 this weekend, if it doesn't rain, and see how the car acts. Also, my fp red is journal bearing, so i don't have that oil leak issue.
No I'm running 93. I also have a jb turbo. I didn't know there was water issues with e85. Makes sense because ethanol would have a small percentage of water in it. Good to know I plan to go flex fuel.
Old Apr 1, 2016 | 12:31 PM
  #33
The STM Can is a sealed system. The difference between a sealed vs vent to atmosphere can is like the difference between a turbo charged engine and naturally aspirated in reverse. Instead of pushing air in to the motor a sealed system uses the turbo to pull air out of the crank case. A VTA system just lets air vent all nauterale. Wich means there is always going to be a very small amount pressure in the crank case to push air out. And since we all drive turbo cars I think we could all agree that turbocharged is better.
Old Apr 1, 2016 | 03:11 PM
  #34
EvoIIIAj's Avatar
Just took a look at it again and I understand the difference now. You seem to have experience in the area, you think I should try the catch can before the valve cover mod? I'm currently on stock PCV set up.
Old Apr 1, 2016 | 04:02 PM
  #35
The way STM sets this up, you don't need the valve cover mod.
Old Apr 1, 2016 | 07:06 PM
  #36
WickedRSEvo's Avatar
Thanks everyone for your responses. I'm pretty much sold on this can. Now, I have to justify $600ish for this kit. Not saying it's not worth it, but that's a lot of money. I dumped a good bit of money into the car this winter. It's not if at this point, but when. Decisions, decisions.
Old Apr 1, 2016 | 09:30 PM
  #37
EvoIIIAj's Avatar
Sucks for me I need to buy the USDM VIII valve cover to use it. I have a JDM VIII which has same valve cover as the VII. I need a new valve cover anyway because of a small crack so time to find over a grand for a cover and this catch can lol.
Old Apr 1, 2016 | 10:46 PM
  #38
You can get a good used cover for 150-200
Old Apr 10, 2016 | 12:58 PM
  #39
N3WBI3's Avatar
Here's my installed pics.
Old Apr 10, 2016 | 01:06 PM
  #40
^ have you driven the car to notice a difference? Were you having crankcase pressure issues prior to install? Looks quality by the way.
Old Apr 10, 2016 | 03:41 PM
  #41
N3WBI3's Avatar
I had blue smoke on downshifts on my fp zero. Just drove it yesterday but am not able to 100% tell a difference since I changed so much over winter.
Old Apr 10, 2016 | 05:24 PM
  #42
That's a ball bearing turbo, correct? Were you blowing the dipstick out before? Leaky valve cover? That's my problem. I have a journal bearing red, so no problem there. I'm just curious what steered you toward the stm.
Old Apr 10, 2016 | 06:29 PM
  #43
N3WBI3's Avatar
The old setup was just VTA where I drilled out the side of my valve cover. After speaking with STM and FP about why I was getting crankcase pressure and smoke, FP advised they would take a look at the turbo only if I had a correct crankcase ventilation system. And VTA was not it.
The dipstick never actually popped out, but it almost did as itwas unseated. And yes, it's ball bearing.
Old Apr 10, 2016 | 06:42 PM
  #44
I have also spoken with FP and STM. I got the same information. So I guess that's good. One last question. What's the third port on the front of the stm can? Thanks.
Old Apr 10, 2016 | 10:43 PM
  #45
N3WBI3's Avatar
I think it's for like a vented dipstick?? I'm not sure. It comes with a -6 plug though better seen here
