Wiseco Boostline rod for evo opinions?
I'm American to the bone, hell yea, *****, beers and bikes. Though I've also come to realize this means jack **** anymore honestly!!
I also thought I read this was not the case anyway and they are in fact made here. Let me see if I can find it as I was reading on a bunch of rods the other night trying to find the right choice for my build. Ugghh quite the daunting task honestly, I gave up for now. I am down to a decision on about 4 sets so that's a plus.
Edit: Yup you're right, in the article posted it says tested and finished here. I'm sure they are actually made somewhere in Asia. Curious to know where my other options are made, don't honestly care anymore as long as they're rated to my HP goal
Wiseco have been know to be mid range components. Good for a budget build with mid rpm/power levels in mind. Normally plain Jane design. But this rod looks interesting. Hopefully it plays the part as much as it looks the part. As far as the bolts go, why not upgrade them yourself prior to putting it together. An ounce of prevention is better than a pound of the cure.
lulzbbq, so you are saying wiseco is the best!?! Number one pick!?! Or would you say if you had deeper pockets there isn't 2-3 or three brands that you would choose over wiseco? With about 6 relevant manufactures that would land the brand in the middle?
I would choose Wiseco HD's, or the ER designed "Top Fuel" pistons, that are made by Wiseco if I was trying to get ridiculously into the 4 digit power range.
I would hardly call this a "mid-level" product in a "mid-level" car. Shelf Wiseco 1400HD's at almost 1100whp. They didn't rev it to 9500 on the dyno, but it routinely revved that high.
https://www.evolutionm.net/forums/ev...084-744-a.html
Or this car:
https://www.evolutionm.net/forums/ev...hp-inside.html
Or this car:
The rods look really good, I would use them. I would upgrade the bolts though.
do to have turned your thread into a back and forth. When the original topic was opinion on a set of rods.
Or this car:
Or this car:
