Rear dif wine after 12 plate upgrade by rrt.
Could to be louder bcuz there are more plates in the rear?? I also have to add I have the Billet aluminum carrier bushings. It always made noise but not this loud.
If you had the Diff out to put the plates in you should always verify your contact pattern. Do a search on it if you've never done it before. Backlash and heal/toe, contact is very important for longevity of the gears
That is causing the wine. Switch to poly urethane side mounts and it will calm the noise down some. Otherwise, if you want it totally silent, a new ring and pinion set with proper setup will get you there. But if you run solid aluminum mounts, you're always going to have some noise.
2winscroll (May 5, 2017)
Thanks for your responses.
The rear diff always had a wine to it ever since I switched to the billet aluminum carrier bushings. However since I got it rebuilt by rrt it's been louder than ever and don't know why that is? Is it because there's 12 clutch plates in there now and not the oem ones. Maybe Idk... please help...
Sounds like they didn't do the pattern setup correctly when they put it back together. Send it to a shop that knows what they're doing. I recommend TRE.
Razor answered the question... probably not a gear contact problem, it's cuz your solid mounts. But it's still a good idea to check the pattern. Anytime you replace bearings or carrier Assy it's needs to have the pattern/backlash checked, if you just throw it back together your asking for trouble.
With the carrier bushing, yes. But the 12 plate upgrade absolutely does not effect gear whine. Gear whine comes from improper setup, or trying to redo the setup on a set of gears that already had a well worn in pattern that wasn't perfect.
uamafioz
Jun 29, 2014 07:29 PM
EVOEvolved
Jun 18, 2013 07:48 PM
