Need some help on my evo 8
So i did something really stupid..havent had my evo 8 for long but i was having an issue with shifting into 4th gear at high rpm..one day driving home from work, a mustang was trying to race me..threw it into 3rd from fifth and as i go to switch into 4th, it locks me out..knowing that was gonna happen, i held it and tried to force it to 4th..as i felt it engage, i let go of clutch and boom the motor over revs and either it popped back into neutral or i put it back into neutral(happened so fast) but damage was done..car still drives and boosts fine but now car dies every time i step on clutch unless i rev it up a bit and theres a whine from transmission area..i lifted up the car and front passenger axle boots are torn..any ideas if its my transfer case or transmission or engine? Or all the above? Any suggestions or ideas?
Sounds like you downshifted into 2nd instead of 4th. If you did, that would explain why RPMs skyrocketed. I would check engine cylinder compressions to see if your valves are still on earth and need adjustments (I wonder if cams can get grooved from over revving). Change your torn cv axle for a rebuilt one just in case you grooved the joints. Try double clutching when shifting to help reduce the stress in your tranny and get that rebuilt (or replace with a used good IX tranny if you can find one). I can't think of why engine dies with clutch depressed. Try checking your boost/vacuum lines and test IAC on intake manifold, maybe something cracked with this jolt. Good luck!
I have no other ideas why it would overrev when you upshift. Even if RPMs drops back to idle in between shifts, once engaged, it shouldn't overrev. Anyway, when you press the clutch and engine dies, I would guess your IAC isn't working right. If you have a vacuum leak, your engine should still idle. Although, I recall reading about a leaky throttle plate causing idle problems.
Okay, I'm wrong. If you have a vacuum leak, it could cause stalling. Build a boost leak tester (Home Depot plumbing section) by buying a plug to clamp to your throttlebody coupler (and buy tire valve to install on that cap). Pressurize it to 20 psi and look for leaks. Where in Cali are you?
https://www.evolutionm.net/forums/ev...e-sealing.html
you recall correct
Q8_EVO
Nov 9, 2009 06:11 PM
TREVORSEVOVIII
Jan 19, 2008 10:15 PM
