Fp Green 73htz spool time.
the SS housings will also make more power than the TS housings. Usually around 50whp more depending on fuel. The SS housings work much better on stroker motors.
My 2.0 with mivec (red) would clear 400 ft lbs at 3800-4000 if I wanted it to where this car isn't coming close at this boost level and looks much later.
A OEM designed TS is going to be alot more fun and make more TQ at much lower rpm then an open housing. The TS Red has plenty of response .
Now , the SS housing will make good power out the top and perform well but it comes with a cost. There was a 1/4 mile 130 + mph SS green awhile back. I still don't think they will go past 8000rpm well, I'm hoping someone will post a clear dynojet graph one day.
2006EvoIXer (Jul 10, 2017)
Spools is "later" but it makes same torque sooner, and more power...LOL
Nah. The dates on both those logs are after I bought the Green. BoostedTuning tuned the 71 and BainsTuned did the Green. These are definitely Green charts.
I believe my HTA71 hit 20psi and something crazy, like 3200ish. I'll have to look to be sure. It was sick.
If someone came to me with a new HTA71 that had all the options my Green has.. I'd probably have to trade. That turbo was just too damned fun.
I checked my logs. The 71 was seeing 20psi at 3200-3300RPM but I also remembered I had the TME hot side which had the TiAl turbine wheel. That thing spooled instantly. Loved it and never shoulda sold it.
My green is seeing 20psi at 3800RPM and I hate it. necessary evil, though.
