Vented VS. Sealed Catch Can Test, which is Better? Watch to find out!
#33
Well I'm going to be running the STM sealed setup with an STM SD intake with re-circulation pipe for the DV. I dont like the idea of "polluting" the cold side of the motor with oil etc, but expect I'll have the stuff off for cleaning if it becomes a problem.
Turbo is a 71HTA.
Hope I made the right choice here vs going to a VTA setup.
Turbo is a 71HTA.
#35
Admin Emeritus
#38
ah come on...for the sake of our internet criticism???
I suppose it's kind of irrelevant though. It pulls that much vacuum in the crank case, regardless of if it's from the Bernoulli effect or static pressure drop due to the filter.
Also, I might have been fortunate in the past in that I really never had turbos that leaked oil though the compressor seals. Seeing all the issues many modern DI turbo motors are having with valve deposits and oil build up in the intercooler, maybe sucking oil into the intake is not any more of an issue then the typical amount spit out by the turbo. At least we have fuel in the intake tract to help deal with it...
#40
Very good information here. I think at the bear minimum, everyone should be running a sealed catch can between the rear of the valve cover and the intake manifold nozzle. This way they are not letting the intake suck oil vapor directly into the combustion chamber like the stock setup does. The only thing I did differently on that side was that I placed the oem pcv valve right at the Intake manifold vacuum nozzle and not on the crank case entry side of the catch can. This way you're not pressurizing your catch can under boost, which can be just another boost leak source.
As long as you are seeing less pressure in the crank case than what it takes to push oil back up the oil return line of the turbo, then you're in good shape.
The more restrictive your intake filter is, the more vacuum you will see at the intake pipe port.
roni4g63
Dec 17, 2016 08:54 PM
XK120
10
May 27, 2009 01:31 PM
NeX
13
Mar 29, 2003 02:45 AM
