bov flutter/compressor surge?
So i had my evo 8 tuned in california at sea level, im running basic mods, intake, full exhaust, evo 9 turbo, evo x bov and a bigger intercooler. I just moved to oregon and I live at about 3500-3900 feet elevation and the car has been running pretty iffy lately, i did a 3rd gear pull and this started happening, is this because of the elevation? My target boost is 24 psi and my car is really struggling to hit that now. I did a boost leak test and there was a very small leak coming from the screw hole to adjust the idle
please chime in if you can, thanks
that was about 70% throttle, there was a couple times i did WOT and it got up to 15 psi and bounced around it and would not pass it
It's been given a set of values based on how much air it should see, to calculate how much fuel. It's not getting enough air now, so it throws the equation off.
When you go up in altitude , several things happen.
The air is thinner and a turbo works on "pressure ratios".
It's going to max out earlier because to make the same boost level, it's got to work at a greater pressure ratio.
Your boost gauge might read wrong. how far wrong depends on whether it's a mechanical gauge, MAP sensor based gauge (absolute pressure) electronic gauge referenced to atmosphere.
A factory BOV will start to open at a preset pressure, the actual pressure depends on the BOV. At 24 PSI boost , it'll be open a bit anyway, add to that the turbo nearly maxed out, that's what limits the boost.
If it's tuned properly, the altitude doesn't matter.
A stock ECU measured volume air, temp and barometer to give mass air flow.
SD measures the manifold density and estimates VE.
But if it's tuned wrong, it's wrong.
gik0geck0
19
Feb 20, 2012 06:12 AM
hazdaddy
66
Feb 8, 2010 09:46 AM
Ph3n1x
18
Jan 1, 2006 11:02 AM
