New J-pipe has no nipple
Hey everybody
so, im installing my BR street core Fmic and in the package, I got a new j pipe that goes along with the LICP to the kit. However, there is no nipple for the (vacuum?) hose on the new j-pipe. What should I do? Thanks.
You can tap into the nipple on the intake manifold. I would just stay away from tapping into the fuel pressure regulator vaccum source. Thats just me tho.
Have fun with that when you're at part throttle, and pressure in the charge pipe is much higher than pressure in the manifold, causing the wastegate not to open as it should.
Also, the BOV needs a dedicated line to function properly. So you have two things wrong in your setup now.
Also, the BOV needs a dedicated line to function properly. So you have to things wrong in your setup now.
fareastkorean
Oct 21, 2010 05:09 PM
EvoSam
43
Dec 16, 2005 11:16 AM
