Built Block recommendations
Old Sep 26, 2017 | 03:04 PM
blackline's Avatar
5 Year Member
so I recently blew the block on my evo 8. Since I don’t have a good core I’m SOL on a couple grand.
Can can anyone recommend a good short block for daily and auto cross?
my current setup is S1 cams, 1000cc injectors, CRBD BBK full, 3in TBE, 70mm TB and Ported mani.
Old Sep 28, 2017 | 01:36 PM
LetsGetThisDone's Avatar
Would probably just put a 2.0L in it. Give English Racing a call.
Old Sep 28, 2017 | 04:48 PM
Tuxevo's Avatar
The 4g64 block is a little cheaper and more available. The added displacement would help with autocross as well.
Old Sep 28, 2017 | 07:01 PM
4b11slayer's Avatar
I dont think the 4g64 is more reliable then a 4g63. Anyhow.
You can check out boostin performance. Buschur. Curt brown. Theres a few reputable builders. But if it were my money id hit up buschur if its still the og buschur. Cause hes ritired or retiring.
Old Oct 3, 2017 | 09:46 PM
4g63Moon's Avatar
I would do a 2.3L with your set up. Torque will come into play and way more fun to drive as daily.
Old Oct 4, 2017 | 08:23 AM
blackline's Avatar
5 Year Member
Thanks!!
ended up picking up a new MAP 2.0 Short block for a good price locally.
Wiseco 85.5MM
9.0:1 HD Pistons
Manley I Beam Turbo Tuff Rods
OEM Uncut crank
ARP Main Studs
ACL Bearings
Old Oct 12, 2017 | 07:22 AM
2winscroll's Avatar
You don't think....what's that a guess? Or statement?
Old Oct 12, 2017 | 07:39 AM
Biggiesacks's Avatar
its a pretty commonly known thing that the 4g64 has head sealing issues.
Old Oct 12, 2017 | 08:58 AM
Originally Posted by blackline
Thanks!!
Wiseco 85.5MM
9.0:1 HD Pistons
OEM Uncut crank
ARP Main Studs
ACL Bearings
That sucks. Good luck.
Old Oct 12, 2017 | 09:31 AM
2winscroll's Avatar
It's pretty commonly known that 4G64 has stronger cylinder bores and unshrouds the valves for better breathing. Head sealing issues are easily resolved with o-ringing the block.
Question was directed towards the poster.
Old Oct 12, 2017 | 09:39 AM
2winscroll's Avatar
What I'm getting at is usually when someone says something is superior/inferior, they give a reason as to why it is so. Not "I think", or "because I say so".
Old Oct 12, 2017 | 09:41 AM
4g64 built correctly run fine. The English Racing 2.4LR build making ~830whp with a 6466 that is sitting in my shop right now (as well as plenty of other 2.4's they've built), and lots of the results TSComp posts prove that. 4g64 head gasket issues are a thing of the past, when guys were experimenting with it and figuring it out.
Old Oct 12, 2017 | 10:46 AM
Yah of course there are things you can do to increase the reliability of the 4g64, but once you start modifying the block/head then your into apples and oranges territory.
Also yah, no replacement for displacement, airflow and all, but that doesn't really have much to do with reliability.
Old Oct 12, 2017 | 11:43 AM
My point of the results is that they also stay together. So it has a lot to do with reliability.
It's not apples/oranges. You need to o-ring the head to make it live. It's that simple.
Old Oct 12, 2017 | 07:17 PM
Teal2nnr's Avatar
Whats wrong with an MAP short block? Im currently running one assembled by them.....
