FP red or black?
Old Oct 20, 2017 | 10:09 AM
itzpunisha's Avatar
Are you going to be running pump gas, race fuel, or ethanol? 500 is a lofty goal for a stock frame turbo on pump.
mostly 93oct, I do have access to Sunoco100 so I will get tuned for that as well
Old Oct 20, 2017 | 01:32 PM
M4Lki3r's Avatar
Veteran: Marine Corps
If you're only going to go 93oct, you might make 500 at the top end of a black. Red won
Red #1: https://www.evolutionm.net/forums/dr...93-octane.html
Red #2: https://www.evolutionm.net/forums/ev...93-octane.html
Black #1:https://www.evolutionm.net/forums/ev...ml#post9463965 See the beginning of the thread for the build.
You'll either need to go non-stock frame or E85 (or maybe stroker) to get 500hp on 93.
Old Oct 20, 2017 | 01:59 PM
LetsGetThisDone's Avatar
Sounds like you need to get a black. It might make 500 on 93. Should do it on 100.
Old Oct 25, 2017 | 10:39 AM
BrownParticles's Avatar
red, I think black would be too big for what you have.
Old Oct 29, 2017 | 08:45 PM
zuppy's Avatar
If you want to make the power on 93 I'd think the fp black ss would be better.
Old Nov 2, 2017 | 07:41 PM
Erik@MIL.SPEC's Avatar
The SS FP Black on a 2.0 is gonna be super laggy.
Not sure if that's what the OP is gonna want.
Old Nov 3, 2017 | 07:34 AM
itzpunisha's Avatar
Yeah i went ahead and bought SS fp red using the holiday bundle promotion. Super stoked
Old Nov 4, 2017 | 09:13 AM
illusin's Avatar
Just going to have the issue with TQ if your stock block ect. I made some crazy numbers on a built 2.3 with a black years ago. Just make sure tuner keeps TQ down and you should be good on the red.
Old Nov 4, 2017 | 12:43 PM
kaj's Avatar
kaj
360whp is impressive for that setup. What kind of fuel were you on???
500whp on pump gas (depending on what you have as "pump gas") usually will require a Black. But I'm from CA where we only have 91 so your results may vary LOL.
**edit, I see you were looking at the SS versions. From what I've read, the SS Red makes the same power/lag as an MHI Black, so you should be okay. Someone will surely correct me if I'm wrong, though.
Good luck, dude!
Old Nov 4, 2017 | 03:08 PM
kikiturbo's Avatar
the question is not what power you want but what characteristic of the engine you want..
Black or SS red will be laggy.. on a 2.0 it will work above 4500 and up to 8 something.. of yourse you do not want to rev above 8 on stock engine. Worst thing is it will have bad transient response..
I would put a HKS 7460 KAI on it and leave it at that... it will be more responsive than stock turbo and give you at least 70 hp more than you have now..
Old Nov 5, 2017 | 01:02 PM
kaj's Avatar
kaj
Honestly, most people only care about dyno numbers/bragging rights. I run into very few people that care how responsive the car is.
A lot of them end up downsizing later, but that's another topic, entirely.
Old Nov 5, 2017 | 05:30 PM
itzpunisha's Avatar
Good luck, dude!
Im on 93 octane. I was tuned by Jay from BoostedTuning. Yeah i went ahead with SS jb red because of the bundle deal.
Old Nov 5, 2017 | 05:33 PM
itzpunisha's Avatar
Also went ahead and got 1100 FIC injectors, Gsc s2 cams with springs and retainers. Should have all installed and tuned within next 3 weeks on 93octane.
import_yaj_guy
12
Aug 20, 2014 09:04 AM
izabran
10
Jan 19, 2009 09:55 AM
confusionisbad
Jun 29, 2007 06:00 PM
evo-53
13
Nov 3, 2006 10:45 AM
Evasive EVO
Evo 'For Sale' Wheels / Tires
46
Oct 11, 2006 02:24 PM
