Garrett G-Series turbos
#197
#198
I went a different route with the EFR I redesigned the bonnet latch and have a tucked dual pass radiator. I can now fit any size IWG T4 EFR in the bottom mount position.
It's easy to fit an EFR, but I can understand you don't have much flexibility with off the shelf parts.
#200
Personally I'd like to see how these turbos work in the little T25 housing. Also I'm still hoping they come out with a T4 divided version. Seems like the turbine flows a ton, and doesn't need a larger turbine housing.
Supposedly the G30 is going to be released at SEMA.
#201
who told you about the g30?
#202
I'm not a big fan of virtual dyno, in any case I had the opportunity to compare my car (g25-660 .92, s2 cams etc) with an other evo 8 with stock cams, stock manifold and Tomei arms. Peak boost is 1.9 bar (Garrett) and 1.8 bar (Tomei) while the top-end boost is 1.6 bar (Garrett) and 1.7 bar (Tomei).
Clearly the maximum power is way different since that stock cams are quite restrictive but the spool region give you an idea of the differen response of those turbos. Here the data of the Garrett:
rpm NM
2.206 165
2.438 166
2.562 168
2.734 173
2.859 181
3.016 195
3.156 215
3.344 240
3.531 268
3.656 300
3.781 335
3.906 374
4.062 414
4.250 451
4.422 475
4.719 484
rpm NM
2.206 165
2.438 166
2.562 168
2.734 173
2.859 181
3.016 195
3.156 215
3.344 240
3.531 268
3.656 300
3.781 335
3.906 374
4.062 414
4.250 451
4.422 475
4.719 484
#203
So, 300wtq (ftlbs) at 4k RPM. What fuel was this? That's pretty if it's pump gasoline or similar.
#204
#205
Isn't the Tomei ARMS M7960 just a 20G/TD06SL2? They are pretty laggy due to the large (and arguably mismatched) turbine wheel. Aren't they all IWG, too? Honestly, any billet wheel stock-frame turbo will put one of those to shame.
#206
So you really think that a standard evo 9 turbo with a 20g billet wheel is capable of: 1) 60lib/min of maximum flowing, 2) >79% of efficiency, 3) 24.5 lib/min of exhaust flowing (like the g25-600 .92) and a stock-like spool?. Forget about commercial dyno image and show me some real data, I'm really interested.
#207
300tq at 4k with the .92 housing is pretty darn good. Cant wait to see what the .72 housing will do on 93/e85... it may give me a reason to move away from stock frame.
#209
rpm NM
2.206 165
2.438 166
2.562 168
2.734 173
2.859 181
3.016 195
3.156 215
3.344 240
3.531 268
3.656 300
3.781 335
3.906 374
4.062 414
4.250 451
4.422 475
4.719 484
rpm NM
2.206 165
2.438 166
2.562 168
2.734 173
2.859 181
3.016 195
3.156 215
3.344 240
3.531 268
3.656 300
3.781 335
3.906 374
4.062 414
4.250 451
4.422 475
4.719 484
Molto bene my italian friend, I'm sure it has some more in it.
Marios
#210
