Pistons for 97mm crank
You would use a stroker piston, and 151.5mm rod. It would be much easier to use a custom compression height piston with a 150mm rod. English Racing does custom pistons through Wiseco, give them a call, they can sort you out. They did custom pistons for me for a 4g63 with 94mm crank and 150mm rods.
Joeekrub
Feb 6, 2013 12:20 PM
94AWDcoupe
Oct 16, 2007 08:44 AM
