8-9k rpm
For higher revving your limiting factor is the stock valve springs, not your cams. You can rev the stock cams out high, but if the valves float because the spring was not stiff enough, you'll still break something.
As ||Demon|| mentioned, the turbo will run out of breath. On stock cams and turbo, I was hitting peak HP at about 6500rpm and it fell off from there. It spooled FAST.
Randal
Nov 27, 2012 06:22 AM
211Ratsbud
Nov 11, 2012 01:22 PM
