Compression results question
Old Feb 23, 2018 | 02:23 PM
jspecteggy's Avatar
Originally Posted by Aby@MIL.SPEC
did you have the throttle open when doing the compression test?
if leakdown #'s are good, thats a positive thing.
how many revolutions did you let the engine turn over to achieve your compression test #'s?
Aby,
I wasn't there so I am unaware of the specifics. I figured if the leakdown #'s are good, then it can't be that bad. Perhaps they didn't turn it over enough times to let the gauge read the peak numbers. I figured, worst case I may have to do a little rebuilding.
Old Feb 23, 2018 | 03:49 PM
barneyb's Avatar
Originally Posted by jspecteggy
Right, I agree. However I cannot force somebody to do something they do not want to do. I could walk away from it, but I figured I've built one before and worst case scenario I have to build another one.
I'd suggest there should be a big difference in price between the one situation and the other.
Old Feb 23, 2018 | 04:05 PM
kaj's Avatar
kaj
If you get a good-enough deal on the car and have the time/money to do so, then definitely no reason not to buy. Projects are (almost ) always fun.
Old Mar 7, 2018 | 09:14 PM
jspecteggy's Avatar
**Update**
I ended up buying the car on the hopes and dreams of good luck. It paid off. I reaccomplished the compression test and the results when done properly were completely different and much better. Cyl #1: 155, #2: 152, #3: 150, and #4: 150. Thank you for everybody's input and assistance!
AKB_EVO
Dec 12, 2016 08:02 PM
dambikeracer
57
Mar 14, 2010 07:43 PM
05blue8
Apr 11, 2009 06:51 PM
Sloop
May 13, 2004 11:31 AM
zlancer
Lancer Engine Tech
17
Mar 5, 2003 01:14 AM
