Compression results question
I am purchasing an Evo and am having some doubts about the compression test results. Engine is a 4g64 bottom end with a IX head. It is running GSC R2's, Supertech .5mm oversized valves and Supertech beehives. Inside the block are Manley 9:1's with an 87mm bore on 156mm I beams, and I believe the crank is a 100mm stroke.
My concern is that the picture I was sent for the compression test shows about 95psi. Lowest I've seen from searches on EvoM is 110psi. The leak down came back good and was even across the board, holding 100psi with 0% leak down.
Should this be anything of concern? Also would the large FFTEC V3 manifold have any influence?
jspecteggy (Feb 14, 2018)
big cams will usually have lower compression plus the ix gasket is thicker...
lowest ive seen on r2 is 125 but the car ran well
if theres a doubt dont buy it and stay away or compression test it while warm to see if it gets better
Compression numbers tell you nothing apart from the fact that they're too low.
Broken pistons often have higher numbers, cams out a tooth often have higher numbers, hotter cams have lower numbers. Cams out the other way give you lower numbers, strokers always end up with a CR that's not what you expect.
Waste of time and effort.
BUT
Looking at the plugs tells you far more and if you're doing a compression test then why didn't you take notice of the plugs?
Most modified cars are lemons.
It's got zero to do with the overlap, it's the intake valve closing point.
BUT
jspecteggy (Feb 15, 2018)
I have an IX with a stock block, 2.3 stroker crank and s1 cams. It measures in at 140 to 150 on crappy harbor freight gauge. one thing I've noticed is that the longer you crank it over, the higher the gauge tends to go until it plateaus at some result. So if you only let it crank one or two revolutions, it might read 100 (it takes time to fill the gauge and hose). I think it is also important to note that bigger cams may read lower pressures because of all the overlap. I would say that if the leak down is good and all of the cylinders read the same compression after 10 revolutions then you're good
The seller should allow you to take it to an independent garage for inspection does not equal the seller took it to his shop for inspection and you weren't there.
