4G64 with Mivec Timing Help
Old Feb 21, 2018 | 10:09 AM
Gschierm's Avatar
Hey guys I recently picked up a 4G64 and was confused on the timing part. I was wondering if I timed it correctly or if I should retard it. Also the Mivec gear has been modified to add more degrees of motion. The car runs with this current timing setup but want to know if I should make adjustments before getting a tune.
Old Feb 21, 2018 | 02:55 PM
SIM08U's Avatar
wats a 4g64?
Old Feb 21, 2018 | 03:10 PM
evolord21's Avatar
Veteran: Army
The cams look good. As long as your crank is lined up you shouldn't have to change anything there.
Old Feb 21, 2018 | 04:50 PM
Gschierm's Avatar
Do you think there would be more benefits to setting the mivec gear retarded 1/2 tooth? Like I said I was kinda confused on other posts I've read and want to get the most out of the car.
Old Feb 21, 2018 | 07:29 PM
evolord21's Avatar
Veteran: Army
No, with the modified gear you should be fine the way it is
Old Feb 21, 2018 | 08:37 PM
deylag's Avatar
Dont mess with the timing unless you know how to degree your cams.
Ramatzio
Oct 10, 2016 06:55 AM
rawkus
Mar 24, 2015 06:46 AM
2006GSR
Apr 15, 2012 08:33 PM
valvetap
Feb 1, 2012 01:23 PM
