Lower my rpm's on my evo 5? - EvolutionM - Mitsubishi Lancer and Lancer Evolution Community
Old Apr 10, 2018, 02:00 PM
Hi.
im using my evo 5 as a daily. I have a rs rear diff if it matters. In 120 kph my rpm's is at 3500. My friend have a evo 8 5 speed. In the same speed it is right under 3000. Could i get a evo 8 gearbox and lower my rpm's or what would you suggest that i do?
ChrisO86 is offline
Old Apr 15, 2018, 04:12 PM
Evo VI.'s Avatar
Evo 7 gearbox is a straight swap.
My evo uses the 7 box, great for freeway driving, lower rpm and higher top speed.
Evo VI. is offline
Old Apr 16, 2018, 12:40 AM
Do you have the gearbox code? On which gear/gears does it lower rhe rpms,only on 5th or 3-4-5?
ChrisO86 is offline
Old Apr 16, 2018, 02:04 AM
Evo VI.'s Avatar
MR953341 EVO 7
W5M51-2-X5B
Ratios C
Final 4.529
1st 2.928
2nd 1.95
3rd 1.407
4th 1.031
5th 0.72
1st and 5th are longer, 2-4th are exactly the same.
Evo VI. is offline
Old Apr 16, 2018, 02:18 AM
Originally Posted by Evo VI. View Post
MR953341 EVO 7
W5M51-2-X5B
Ratios C
Final 4.529
1st 2.928
2nd 1.95
3rd 1.407
4th 1.031
5th 0.72
thanks pal. gonan see how easy it is to find that gearbox here in sweden. you dont have the part number for the evo 8 box with the longer ratio if so?
ChrisO86 is offline
Old Apr 16, 2018, 02:23 AM
Evo VI.'s Avatar
The evo 8 gearbox is not a straight swap.
It uses a different type of transfer case and mounts.
Evo VI. is offline
okey. so i cant use the transfer case on a 8 box then?
ChrisO86 is offline
Old Apr 16, 2018, 02:41 AM
Evo VI.'s Avatar
I wouldn’t bother mate.
7 box will do what you need, with less labor charges from the garage.��
I saw your thread on the MLR.
Evo VI. is offline
Old Apr 16, 2018, 02:43 AM
Weird, according to antony on indigo gt, the evo 8 gearbox is bolt on with the evo 5 transfer case?
ChrisO86 is offline
Old Apr 16, 2018, 02:45 AM
Evo VI.'s Avatar
It’s probably just the box mount that’s different then.
The 9 is definitely not compatible. And stay away from 6 speeds
Evo VI. is offline
Old Apr 16, 2018, 02:47 AM
It probably is mate. A 6 speed isnt going near my car haha. Thanks for your help anyway
ChrisO86 is offline
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
