po171 - System too lean (Bank 1)
I got the P0171 code twice. I got that after installing the AFCII with APEX filter, with APEXi specific setting (comes with the filter) which lean out the idle and low rpm. I got the CEL on when the car is idlling one day after and in very low rpm another day. I just zero out the low rpm range of the AFC today and hope that fix it.
i agree with kcevo.. it just happened to me this week when i was playing around with the low throttle settings on my safc2.. so i just went back to zero adjustments under 3000rpms.. i'm gonna play with it again using my wideband this weekend.. cus my mpg is just horrible!
I totally dismounted the AFC and I still get it. Not the tuning because I have this before Turbotrix flash my car, I went to autozone to check the code again, the guy pull out a little booklet. For P0171, system too lean, It could be a/ MAF sensor, b/ Oxyen sensor, c/ vacuum leak.
