Setting T belt tension question
So I'm in the middle of changing a timing belt on my evo 8. Some of the thread I read said that you rotate the tensioner pulley until the gernade pin freely moves. I also seen another source say the torque setting for it is between 31-38 in lbs. If I do it either way the pin does not come "lose " and I even torqued so much yesterday I snapped a pin on my special tool. I am rotating the pulley counter clockwise as well. It is also a oem tensioner and tensioner pulley.
You're probably adding too much tension with the pulley, and compressing the tensioner. Most cars I've done, the holes on the tensioner pull are point at about 4-5 O'clock.
that's about the ball park or where mine was to. I am just worried about under/over tensioning everything.
no I pulled the pin after setting it, let it sit for 20 min came out and cranked the motor by hand and everthing lined up and I was still able to slide the pin in and out fine. When i went to torque the crank bolt I put the cam gear lock back in and went 60-90-120 and was 120 it skipped the tooth.
Crank is one or two teeth off. It happens when you have the slack in the belt between the oil pump and crank instead of between the crank and intake cam when you tighten the tension
I created a tool, a thick steel strap, I've had it since my DSM days, that bolts to two holes on the crank pulley and then on my Evo engine, fastens to one of the accessory belt tensioner mounting holes. This locks everything in places when R&R the crank bolt. So, remove the damper, apply the tool, and buzz off the bolt.
Hotsauce101
Mar 28, 2016 06:24 PM
ethan169
Aug 11, 2011 05:09 AM
Lazyfong
May 1, 2010 12:09 PM
