Transmission question/issue
Old May 8, 2018 | 07:50 PM
thedru13's Avatar
I think I know the answer but thought I would post. I have an Evo IX MR. I still have the 6spd. It has been rebuilt. Just recently i have been having a really hard time getting into gear. Reverse is the hardest but I have issues in almost all gears. Gets worse as it heats up. I don't drive the car much so it sat all winter. I thought maybe the Clutch master cylinder was bad so I replaced both that and brake master cylinder. I flushed the fluid and bled the entire system. No air in the system at all. The issue didn't improve. I then did a trans fluid change. Fluid looked great no metal at all. The situation didn't imporove. I checked all the cables and bushings everything looks in tact. I have a Twin Disk in the car with about 10k miles on it. I don't launch or track the car. Was trying to avoid pulling the trans but I think that is my only next step unless I am missing something. The slave looks fine as well no leaks or anything. Just feels like the trans is having a really hard time engaging. Hence the post so if anyone has any other thoughts all ears or am I just avoiding the inevitable and should just pull the trans.
Old May 9, 2018 | 11:59 AM
evo9_mike's Avatar
Have you tried adjusting the clutch?
http://www.evomoto.com/tech_articles..._article_id=28
Old May 9, 2018 | 12:41 PM
2006EvoIXer's Avatar
Get to your slave cylinder and press the piston in as hard as you can. Does piston slowly retract inside slave cylinder? If it does retract, try double or triple pumping clutch before putting in gear.
Old May 9, 2018 | 12:52 PM
Old May 9, 2018 | 02:13 PM
thedru13's Avatar
I did try this. I have the adjustment all the way out. Can't increase the travel any further at this point. I will double check to make sure wish it was this simple.
Old May 9, 2018 | 02:14 PM
thedru13's Avatar
I will test that out. I have not tested the slave. I will see if pumping the pedal helps at all with engagement.
Old May 9, 2018 | 02:34 PM
it won't help if your master cylinder is adjusted beyond the relief spot where slave piston is supposed to retract when you push. This point allows slave cylinder to stay partially extended (AKA self adjusting) so when you press clutch pedal, it starts extendfrom that point. If it is hard and doesn't retract, no matter how often you pump the pedal, it keeps going all the way back and forth and won't make any difference. The video explains it better.
Old May 9, 2018 | 08:08 PM
barneyb's Avatar
Twin disk clutches are prone to warping. I suggest pulling the transmission.
Old May 9, 2018 | 08:13 PM
what causes warping? Hard launches? I have 700 miles on my Exedy.
Old May 9, 2018 | 09:00 PM
kikiturbo's Avatar
i also think you have clutch drag...
Old May 9, 2018 | 09:11 PM
I had clutch drag when Exedy was first installed. I adjusted for max throw by following video about 100 miles into breakin and clutch drag went away.
seankhan
49
Nov 26, 2019 01:43 AM
eburhans
Lancer Tranny/Drivetrain Tech
14
Aug 28, 2011 03:35 PM
SSP Jeremy
EvoX 'For Sale' Engine Internals and Drivetrain
24
Feb 19, 2011 07:26 AM
Pro
Sep 18, 2007 02:15 PM
be12nard
Mar 11, 2005 09:15 PM
