buschur intake, car wants to stall when.....
Old Apr 11, 2004 | 06:46 PM
metaphysical's Avatar
Registered User
<- Same thing! Trying to figure it out!
Old Apr 11, 2004 | 06:56 PM
mrdecibel's Avatar
vb
This is a known issue with some cars. Whomever you talked to at Buschur either did not understand you or did not know anything. Every since the first person put on an aftermarket filter, these symptoms have appeared. I have the symptoms as well. It will help if you ease off the throttle in stop-n-go traffic. Others may not experience this due to various driving styles. The abrupt start and go affects the air/fuel reading. Try babying it more and see if it helps.
Old Apr 11, 2004 | 07:58 PM
evomind's Avatar
i can baby it more, yes, but in stop and go traffic abrupt stop and go is the nature of the beast. theres no getting around that. the car is a hassle to drive. if i hand the keys to anyone else, it dies. even the mechanic at AMS....it shouldnt be this tricky driving a street car that basically has a bunch of bolt ons....my wife knows how to drive stick and i know it will die with her behind the wheel. my buddy drove it once and hes been driving stick cars all his life....hes like "what the f... is with this thing..?"
if its a case of putting the stock intake and air filter on, thats what ill do...then ill have to have it tuned again.....
now i have another issue ill cover in a seperate post.....
car shudders under partial acceleration....
Old Apr 13, 2004 | 06:56 PM
Registered User
Bump Bump Bump...
I'm left wondering if I'm going to tear the honeycomb out of the MAF, buy a AEM EMS, convert to MAP, and keep the stock ecu in the car incase of OBD2 emmission tests.
It's really annoying, and I can drive around it, but I don't think I should have to deal with it.
Old Apr 13, 2004 | 11:24 PM
evomind's Avatar
my thoughts exactly, metaphysical.....major pain in the *** in chicago traffic.....now i have another issue...gonna try to get it sorted out....if i didnt have so much money in this pain in the ***, it would have been up for sale already......
Old Apr 15, 2004 | 10:21 AM
David Buschur's Avatar
Ha, I just got done telling someone there is no problem with running just the filter upgrade and I come across all this.
For those of you having trouble do you have just the filter or the filter and a MAS pipe? The cars with the MAS pipe upgrades have to have more fuel added down low on the flash or the AFC to get rid of the problem. The filter kits, from what I have seen and driven, by themselves don't cause any trouble at all.
Let me know.
David Buschur
www.buschurracing.com
Old Apr 15, 2004 | 10:38 AM
MalibuJack's Avatar
I've been running the filter for some time.. It works fine in most ccircumstances.. I did notice stalling began to happen recently.. Noticed two things.. Dirty filter, and Fouled plugs.. When I cleaned the filter, and replaced the plugs with colder denso's my stalling problem went away completely.
Old Apr 15, 2004 | 11:04 AM
MrBonus's Avatar
Let me know.
David Buschur
David, how do you add more fuel down low with an AFC?
Do you simply add a couple of % of fuel at 800 and 1000 RPMS at low-throttle conditions?
l2r99gst
Aug 28, 2011 03:39 AM
RoadSpike
Jun 29, 2010 03:48 PM
nitz
Jul 4, 2009 09:14 AM
Tom-05-MR
Aug 14, 2008 02:35 PM
dubbleugly01
Oct 5, 2006 09:32 PM
