Injector seals leak
Old Jul 20, 2018 | 02:27 PM
BrunoBoy650's Avatar
Injector seals leak
Hi guys,
I have searched the forum but need some help. I was boost leak checking my 03 evo 8 and I found that the lower seals are leaking pretty bad. Primarily the two closest to the timing belt. I have replaced the o rings and insulators with Oreillys part number I found on here. No luck with the new seals as they still leak. I tried adding an o ring to the top portion under the rail to give it more pressure when locking them down and still leaking. I have OEM fuel rail with RC1200 injectors and stock intake manifold. Please let me know what to do.
Old Jul 20, 2018 | 04:13 PM
Years ago i went down this road trying to use "off the shelf" inj seals. I remember measuring them w/calipers noting a significant difference from OEM
I ordered OE seals!
Old Jul 20, 2018 | 05:15 PM
I ordered OE seals!
thats what I was afraid of, buy once cry once I guess lol. I just went with everyone’s recommendation of the BW kit from a thread dated years ago. I also saw threads where people used spacers or grinder down spacers.
Old Jul 20, 2018 | 05:23 PM
hutch959's Avatar
the FIC seal kits work also...
i think they are $25 for all of them.
Old Jul 20, 2018 | 05:24 PM
Found my older post from 2012. Wonder if this is the same seal you used (BWD 274531)
https://www.evolutionm.net/forums/ev...uto-parts.html
Old Jul 20, 2018 | 05:57 PM
Any special version of it?
Old Jul 20, 2018 | 05:58 PM
That is the kit, oreillys uses a different part number now though that replaced that kit.
Old Jul 20, 2018 | 06:09 PM
LOL, read my post from 2012. A fountain of E85 spraying from that BWD 274531 seal
Good catch on your part, as well
Old Jul 20, 2018 | 06:32 PM
Its funny because I read your post before I bought the seals but overlooked them not working with RC injectors. So OEM works?
Old Jul 20, 2018 | 06:53 PM
Yes, Thats what i ended up going with
Old Jul 20, 2018 | 08:32 PM
were you good with the rail seal and spacer from the kit? Also did you need to use any other spacers?
Old Jul 21, 2018 | 05:03 AM
i just used the upper O-ring of the BWD kit. The OEM seals were used at the intake port location (no added seals or spacers)
Old Jul 21, 2018 | 07:43 AM
Sounds good. Thank you.
Old Jul 22, 2018 | 04:17 PM
boost leak solved. While I’m waiting for OEM to arrive I went to Home Depot Racing and picked up Everbuilt 3/8 Neoprene grommets, installed and the only one leaking boost was the one closest to the timing belt. Added an oring between the fuel rail and the middle injector spacer and re boost leaked checked. 30 psi and no leaking out of any seals.
Old Jul 22, 2018 | 04:30 PM
HDR for the win Good to hear youve ordered the correct OEM's
Although not understanding the relationship between a boost leak & injector seal leak?
