Throttle hesitation in EVO 8.
Old Sep 3, 2018 | 01:29 PM
timothyhowe's Avatar
I have a 2005 Evo8 with 250,000 miles. Last 4 years I have had brief intermittent losses of power while accelerating. In after market stuff I have a new "chip" which leans down the fuel/air mixture, after market intercooler, after market exhaust.I had a engine rebuild in 2014.If anyone knows what to do about this I would appreciate it!
Old Sep 3, 2018 | 01:53 PM
kaj's Avatar
kaj
I'd start by getting rid of that "chip" and go from there. Then, you can start eliminating other possibilities.
Old Sep 3, 2018 | 03:06 PM
O.K. thanks! That will probably be the easiest place to start.
Old Sep 3, 2018 | 03:28 PM
kaj's Avatar
kaj
No prob, Bob. It's usually best to eliminate added stuff from the equation so you don't chase your tail. If I had a dollar for every time a chip, turbo timer, or after-market alarm caused a problem, I'd be a rich man
Old Sep 6, 2018 | 09:49 AM
gqcode's Avatar
Veteran: Air Force
Boost leak test would be next and changing the sprk plug after that. If you noticed a power loss it probably you compress air leaking from maybe a coupling for me I to replace the o ring the the trottle body. Which are common to leak on the 8 and 9. but do the test first
Old Sep 6, 2018 | 10:11 AM
Thanks will share with my mechanic soon. Tim
Old Sep 6, 2018 | 10:24 AM
kaj's Avatar
kaj
Boost leak would be a continuous loss of power, not intermittent. Plugs are a possibility, but I assumed those have been checked.
OP: also check the turbo for shaft play, as well as signs of the wheels hitting the housings. I had a similar problem as you when my turbo was on its way out.
