Evo 8 2.3 6262 misfire?
Old Nov 2, 2018, 03:28 PM
03BBY1088's Avatar
My car has what it seems to be is a misfire.
idle and little throttle seems to be fine but if I try to give it about 30% ish of throttle on highway to speed up or try to floor it, it sounds like a Subaru kinda and has a really bad stubble to it and also afr gauge goes lean
all I have done so far is check ignition coils with ohm resistance test while Cold , installed oem coils and still does the same. Check the gap on plus and they all are right around .018-.019
like I said idle is fine, I drove it a few weeks ago and didn’t seem to have this problem but it was breaking up some during WOT, but always cleared up
I plan on replacing spark plugs, and from what I’m reading a few people are getting a few different things from bad ignition coil, possibly clogged injector, possibly clogged fuel pump sock
Old Nov 2, 2018, 07:50 PM
MasterNater's Avatar
Going lean under throttle would indicate a fuel flow issue. If you're running E85, clogged injectors is a safe bet.
Old Nov 4, 2018, 03:21 PM
03BBY1088's Avatar
That’s what I was thinking too, will check this week
Old Nov 24, 2018, 06:25 AM
03BBY1088's Avatar
Bump
Old Dec 3, 2018, 07:10 PM
Teal2nnr's Avatar
I had a similar issue at one time and it was the exhaust cam position sensor. Give it a test and see. They ten to go bad sooner if you don't have a heat shield over them and you're running an aftermarket manifold.
Old Dec 5, 2018, 09:08 AM
2006EvoIXer's Avatar
Do a compression test to verify that your valves are seating completely.
