Another Slim Fan thread...
I ended up purchasing the full size mishimoto radiator during BF as mine is leaking. I'm currently thorn between the Mishimotor fan and the SPAL. Anyone have any recommendation on which one I should get or maybe another slim fan options.
Thanks
Thanks
Remember you want a pull fan not push. Pretty sure this is what I bought and it came with 2. You can find in different sizes depending on clearance needed.
https://www.amazon.com/Performance-Electric-Radiator-Mounting-(Diameter/dp/B01NBMKMVY/ref=zg_bs_15725421_3?_encoding=UTF8&psc=1&refRID=1 JHEDN34MMVHV2E1SNAN
blackline (Dec 5, 2018)
I have that Mishimoto fan with the aluminum shroud. It saves some weight over the oem one, however there are some con's to note on this that you may want to consider.
- The wiring on the fan is not plug and play, you will need to use your oem harness plug.
- Clearance issues to consider: the plastic fan shroud that mounts to the aluminum housing has a tight clearance near the oem wastegate area. I am running a turbosmart wastegate and I needed to modify the plastic fan shroud. If you are running stock motor mounts, the additional engine movement may cause some additional clearance issues. I'm running the Torque Solution engine mounts, so the movement is not as much as with the oem mounts.
blackline (Dec 13, 2018)
