Rear differential horrors. Weir 12 plate, installer error, and more.
#31
Thanks for the info, and sorry you had to go through this.
Quick question about the driveshaft, I’m assuming it’s a Drive shaft shop carbon fiber unit? Any issues with it or the install? Pros & cons? I’ve been thinking about pulling the trigger but would love some input from someone who’ll be a straight shooter. Thanks
#32
I bought it because I'm trying to get the car under 3000lbs.
APEXR (Dec 22, 2018)
#37
I'm pretty sure the TRE upgrade is cheaper than buying new OEM plates. Shep does an "upgrade", but all they do is add more OEM plates to your existing set. Not sure how that plays out, if your OEM stuff is old and worn. I guess it would be a band-aid fix and help some....? I voted "no" on that one and went with TRE. That diff straight HOOKS UP now. Between that and the tuned ACD, the car feels very much RWD in the turns, just the way I like it.
