Who Would Be Interested in a Drop In EFR Turbo?
#46
ALL motorsports turbochargers are water cooled regardless of CHRA material lol
Except Precision. But thats because they use an old Garrett design.
#47
It's not a stressed member, nor does the center housing get nearly that hot. You can paint center housings with non high temp paint and it won't flake off. Most turbine housings are made of a high nickel alloy steel like inconel or in the the case of EFR stuff it's stainless, and the thermal properties of those metals do a good job of keeping the heat in the turbine housing without letting the center housing to get even close to the 950C number you said.
Furthermore I wouldn't run ANY turbo on a road course car without water cooling, it's a really good way to coke the oil and have it break down at an accelerated rate. You should double check to make sure those motorsports cars don't run water cooling because Garrett is a HUGE proponent of using water cooled turbos. If by chance they aren't running water cooling, I can assure you that they're changing oil between every race, which can be a considerable expense for an average privateer.
This isn't a Garrett vs Borg Warner thread. The EFR stuff has been out for around 15 years now and is still run on some of the fastest time attack cars in the world, it's pretty well proven.
I'll be reaching out to companies throughout this week to see if I can find a company that's interested in marketing this housing. Today I also had someone send me this:
It looks like Driven Fabrication is going to be offering EFR bolt in turbos for the Evo X. Unfortunately we can't run it as we got the short end of the stick since the X doesn't use a reverse rotation turbo like the 8/9 does so we can't just machine a stock housing.
Facebook Post
#48
For example, here's a picture I found of a Garrett Motorsports TR30R with cast iron center housing and no water cooling. This one looks to be using a SS turbine housing instead of inconel, but it looks like it has the magnesium compressor housing:
#49
So turbos not available for consumer purchase. Got it. Now let's please keep that out of this thread because it's not about any of that.
if someone doesn't want to run water cooling they can purchase an EFR with a cast iron center housing and plug the water ports and see how tht works for them.
#50
#51
@kikiturbo could you get me a rough measurement of the diameter of the compressor cover on your 7163?
I have very little doubt that the B1 frame stuff will have any issue fitting in stock location, I think the "B" compressor cover might be a squeeze, it only looks a tad higher than the "A" comp cover but I don't think the "C" cover will have any chance of fitting. The 7670 is the largest turbo that uses the "B" cover.
#52
#54
yeah, but the WG canister gets in the way...
as I said.. my complete setup doesnt protrude further from the block than the OE solution... your challenge is making a cast manifold that bends enough to work with normal rotation turbo unit..
