6 speed housing crack around clutch fork pivot
Old Mar 18, 2019, 10:51 AM
kikiturbo's Avatar
Got this 6 speed in today... Car had really worn clutch that went to the floor on the second test drive... Took it apart and found this:
Part fo the housing that holds the clutch fork pivot broke off... Scratching our heads on how to fix it right now..
Old Mar 18, 2019, 11:05 AM
DontStopMe's Avatar
Hate to say it, but it looks like you never released the throw out bearing... And you(or whoever removed the trans) did this damage upon removal.
Eitherway, if the internals are still good inside the trans, just find a new case(front half).
Or, 5 speed swap to the better gearbox.
Old Mar 18, 2019, 11:17 AM
kikiturbo's Avatar
no, it broke before we took the trans off.. I could see the spring hanging from the access hole.... We actually had to unbolt the clutch cover and then cut the retainer off from the clutch disc side..
Old Mar 18, 2019, 11:35 AM
Pal215's Avatar
Damn that sucks, but sounds about right. When the clutch fork pivot shaft or surrounding casting arms are broken, there is no way to easily release the TOB even when using the flat head method. Sounds like you guys had no choice.
Old Mar 18, 2019, 11:39 AM
kikiturbo's Avatar
well, sometimes the TOB will get stuck and in those cases we will unbolt the clutch cover.. that is normal.. Broken gearbox casing is another matter..
Old Mar 18, 2019, 11:49 AM
DontStopMe's Avatar
Well that sounds awful (to have to do!) Did you still try to release the TOB/collar before doing it?
I guess i didn't think about trying to release it with the part that hold the fork broken off. Just saw half the collar on the TOB and knew it didn't look right.
The only proper fix that i see is getting a new front half of the case.
Old Mar 18, 2019, 12:01 PM
kikiturbo's Avatar
we did try but the TOB collar looked messed up too..
I have a spare 6 spd box that I can use or we will get a new case. We are also investigating another option of fixing it but that will require some precise machinig..
Old Mar 18, 2019, 02:40 PM
Pal215's Avatar
If you have the parts that broke off, you might be able to get away with welding the cast aluminum back on and grinding down the excess with a dremel sanding bit.
Old Mar 18, 2019, 02:59 PM
kaj
kaj's Avatar
I have two broken 6spds sitting in my driveway. Both have good cases. Free ,if you are ever in Central Kalifornia!
Old Mar 18, 2019, 03:03 PM
Pal215's Avatar
Do I see a trans autopsy video/ picture thread in the future? Would love a How To take apart 6 speed thread
Old Mar 18, 2019, 04:46 PM
kaj
kaj's Avatar
If I have time, I could. I'm 80% school, 10% family, 10% dogs now until June. I plan to pull them both apart to scavenge the hardware, anyway.
Pal215 (Mar 19, 2019)
Old Mar 19, 2019, 12:13 AM
kikiturbo's Avatar
hell, I will do one real soon..
Old Mar 19, 2019, 12:14 AM
kikiturbo's Avatar
I have a friend coming over from CA real soon.. but I will not burden him with that... thanks for the offer..
Old Mar 19, 2019, 02:18 AM
Fox_IX's Avatar
Wait for real? Bro I'd totally pick one of those up. I'm in Santa Cruz
Old Mar 19, 2019, 01:17 PM
kaj
kaj's Avatar
Feel free to grab one. Hurry, because I plan to take all the bolts out, to keep.
