Can’t Shift Into 1st 3rd or 5th
I was driving in 2nd gear today when all of a sudden I couldn’t shift into 3rd unless I put it back in neutral, back to 2nd, then 3rd. I parked and with the engine running and the clutch in from neutral, I couldn’t shift into 1st 3rd or 5th. As soon as I put it in 2nd 4th or 6th I was able to as long as the clutch was pushed in the whole time. If I let go of the clutch and put it in neutral, I can’t put it in 1 3 or 5 again unless I put it in another gear first.
I have no idea. I got the car in August of last year and the previous owner also had no clue. He only had the car for a couple of months.
I checked the cables and one of them going under the intake manifold looks like it has the rubber coming off of it. Other than that they seem fine. How do I go about checking the shift assembly on the trans?
It sounds like something is out of place and moving the shifter down (gears 2, 4, and reverse) temporarily puts it back.
I could give better hints if I could remember which cable moves the assly in which direction LOL
