Do Kelfords 272 make way more power then bc 272 ?
hello Guys,
Im currently running a stock frame Gtx 3576R on a stock bottem end evo 8 pushing 31 psi with aquamist hfs3 on 50/50.Car is making 452 whp/390 wtrq on a pretty conservative afr and timing map.Car has every single bolt on, will i see significant gains if i switch to kelfords 272 cams ? Im looking to hit 500whp 400 wtrq or less.
i know they wont make 50 whp for sure, but the tune is currently conservative im running 10.7 afr and 14 degree up top so its not pushed ,My question was about kelfords over bc 272 on such setup at theese boost levels,Is it worth it ?
i will definately push the tune more.
The gain is going to be big. It may not gain 50HP at the power peak, but there may be a 50HP overall gain in there somewhere.
Reminds me of this: https://www.dsmtuners.com/threads/ol...p-gain.426118/
The HKS 272 is very similar to the BC 272, and the GSC S2 is very similar to the Kelford 272.
