2.3 Build
2.3 Build
2003 Evo 8 GSR
Spun a bearing recently and I知 doing a full overhaul. I have new oil pump, strainer, cooler and filter of course. I知 going to leave stock cams and valves for the time because it痴 still somewhat budget. I have a little rust around the car because it spent some time up north but nothing catastrophic. New exhaust studs for that. And I知 getting ARP head studs. Looking for recommendations on replacing the balance shaft and whether or not it needs to be new or if I can leave the old one in. Also looking for recommendations on rotating assemblies. Brands, strokes, bores. I知 new to the engine building thing so any comments are helpful! Also for the time I知 keeping stock turbo and exhaust manifold. I値l worry about those and any other bolt ons later. Also remote tuning recommendations would be great! I don稚 have any import tuners local.
I wouldn't build a 100mm motor. Stick with a 94mm crank, you can still run 150mm rods with the appropriate compression height piston (I think CP makes a shelf piston for this combo). Eagle forged is a great crank, rods will depend on torque/power goals.
Balance shafts should be deleted.
I would not use a 156mm rod with 94mm crank. The short compression height does not work well. There is a reason English Racing spent the money to use custom 153mm rods when they were first developing the combo.
Theres an import engine builder not too far from me that recommended a 4g64 crank, so 100mm stroke, 85mm pistons and 150mm rods. What does anyone have to say on that?
I mean...
What are the downfalls of 100mm? Where would you recommend I find that stuff? Every kit I find just seems like they池e 100mm or like crazy big pistons or stupid long rods that or they池e just factory length and I don稚 understand how they would end up upping displacement. I know these are probably dumb but I知 trying to figure it out haha
You can give English Racing a call, they can set you up with a rotating assembly.
The Honda motors that rev to 9000rpm stock have what you term more HORRENDOUS Rod Ratio, and Evo X stock has worse rod ratio than 4G63.
Its a number.
If I knew nothing about the engines, like my wife, and heard this comment, I would of course take it for granted and unfortunately make assumptions and choices guided by such strong words.
I think we have to be more objective than that.
Perhaps we should say that "on paper" the 2.3 on 4G63 has rod-ratio which seems less desirable?
However, in reality, there are many successful road and race Evos running the very 2.3. Additional benefit is improved spool gained by 100mm crank over 94mm crank.
You can have your opinion and voice it of course, but I would not want a new-to engine-building fella here to take this Horrendous term for gospel, because it is not a true-statement in engineering terms.
Nobody has ever measured, that I am aware of, the actual difference in longevity under certain use of 2.2 vs 2.3, 94 vs 100 mm strokers.
We have seen graphs of theoretical side loading.
But as they say, the proof is in the pudding, and if anything, the proof in the pudding suggests 2.3 works just as well as 2.2 for virtually all.
My $0.02 cents as they say.
I love the 2.3, and unless I had a race car living at 10K rpm I would not go 2.2.
The loss of spool and low end torque, the fact that 2.3 will happily rev out to 8500 and that cam and turbo choice virtually dictate the efficiency range up to 8.5K rpm...means that we realize most benefit on road and road-course, form 2.3.
Which is why RRE and similar road-race oriented shops favor 2.3.
Its a number.
Although in theory rod ratios do affect negatively or positively the efficiency and longevity of an engine, in reality that effect is not so crucial. In reality, 2.2, 2.3, 2.4 configurations work well, when build right. It is all down to what one wants from his setup and his intended usage of it.
Marios
Marios
2.3 rod bearings, pistons, and cylinder walls always look worse than 2.2 stuff, every single time. There is a reason some shops don't even build 2.3L's with the 4g63 block, and some of those shops actually set records.
You give maybe 200rpm for boost threshold with a 94mm crank instead of 100mm. And the motor is a happier one.
The Hondas youre referring to don't have a 1.5:1 rod ratio. They are all 1.55 or better. B18 for example is 1.58:1 (close to 2.2slr 4g63), K20 is 1.62, K24 looks to be among the worst at 1.54.
Things also get much different when you're talking boosted vs N/A. There's a lot less load on the rotating assembly in an N/A application since they generally don't make as much power per liter.
