Timing 2.4l evo 9 mivec. Pics for assurance! Ty!
#32
Sad but im not even sure this motor has the 180 issue
#36
If you are running a 4g63 block then no. He has a 4g64 bottom end so the block itself is 6mm taller than the 4g63 block is. There for using the stock cam gear the timing marks won't line up. He is using his adjustable cam gear to adjust the cam so that it will allow the cam to be set at 0 degrees.
#38
The only way to get zero compression is a bad tester or the valves aren't closing.
#39
#42
Though, probably right. Valves are probably open when they shouldn't be. Either timing or held that way. The sound of the engine when cranking seems like its building at least a slight bit of compression but dumping it or releasing it. So could very slight. The sound with absolutely no compression is a smooth even sound with no lumps.
#43
Either you put too much faith in peoples ability or you're not thinking outside of the box hard enough
#45
You leave the timing belt on to do a leak down test. Just rotate each cylinder to TDC. You may need someone to hold it in place.
