Need Help with Evo 9 Cams
Old Jun 9, 2019 | 04:55 PM
Kong Vaj's Avatar
So i plan on buying cams for my evo 9. Its a stock block with fp black, bolt on, and a 450 pump. Was wondering if i can run cams without upgrading my valves and springs. Any suggestion on what cams i shoud get. trying to hit 450HP.
Old Jun 9, 2019 | 05:25 PM
Run those S2's! (many of us do!) Must get the springs for sure! I would get the Ti retainers as well!
No need for any valve work.
Old Jun 9, 2019 | 05:34 PM
Kong Vaj's Avatar
Okay thanks bro.. I'll look into it.
Old Jun 9, 2019 | 05:38 PM
The modest lope is very addicting
Old Jun 9, 2019 | 05:42 PM
Kong Vaj's Avatar
Hope to hit the 450s
Old Jun 9, 2019 | 05:58 PM
Im running the S2's on stock internals & the FPHTA71 & tuned at 460 Dyno jet WHP
Old Jun 9, 2019 | 06:03 PM
Kong Vaj's Avatar
So just get the s2 cams and springs..
Old Jun 9, 2019 | 06:13 PM
Yeah, The S2's w/the springs & Ti retainers
I assuming youve the fuel pump & injectors & the other supporting mods?
Old Jun 9, 2019 | 06:17 PM
Kong Vaj's Avatar
Not the injectors yet. Not really sure what size injector I should go yet
Old Jun 9, 2019 | 06:49 PM
Yeah, im running small RC1000's & they are tapped out on my E85 tune
If im not mistaken, our engine Gurus, would suggest a min, such as the ID1300's
Old Jun 9, 2019 | 10:20 PM
LetsGetThisDone's Avatar
S2's and the appropriate spring/retainer is kit is a good choice, the GSC 5040 part number.
Are you trying make 450whp on pump gas or E85?
Old Jun 9, 2019 | 11:15 PM
Kong Vaj's Avatar
need help with cams evo 9
So just wondering if I can run cams without doing vavles and springs. If so what do you guys recommend me getting for cams? I got full bolt on n fp black with a stock block. 450 walbro pump. Trying to hit 450. So let me know what you guys think about the cams?
Old Jun 10, 2019 | 12:50 AM
kaj's Avatar
kaj
Based on limited info, You need bigger injectors and e85. Then 450 will be cake, even without cams. On pump gas, a mild cam will help. Maybe something not requiring springs. Hopefully someone can come in. Also, you would swap springs and maybe retainers. No need to change valves.
Old Jun 10, 2019 | 12:54 AM
Kong Vaj's Avatar
Yea for sure I'm going e85 n think about 1450 injectors.. but was just thinking about throwing in cams also
Old Jun 10, 2019 | 06:21 AM
Why did you start another thread?
