Old school FP RED GT3583R rebuilt GTX3582R
Hi,
I am wondering if anyone has upgraded their Old school FP RED running a GT3582R compressor wheel with a journal bearing and rebuilt it down the road with a GTX3582R compressor wheel and still keeping the journal bearing. The turbine in this i believe is from a TD-06H? It has 11 blades
I am currently going down this road and I want to see if there is any data on the performance... What are the spool times like with the gen1 GTX3582R vs the old school GT3582R
Being such a unique turbo there is not much info out there.
Thanks for any input
MinusPrevious (Jul 6, 2019)
Have reqeusted one of our good members,who has done some turbo rebuilding, to post up
@2006EvoIXer
@2006EvoIXer
Volcom86 (Jul 6, 2019)
The following 2 users liked this post by 2006EvoIXer:
MinusPrevious (Jul 6, 2019),
There is an KTS 3582r 6 blade Billet and extended compressor wheel that fits the Old school red turbos. Along with swapping some thrust parts to match.
And correct, the old school reds came with a 11 blade TD06HR turbine wheel.
now there is one person in the DSM community named Jason Drew who has upgraded his old school red to the KTS 6 blade Compressor wheel, and swapped the 11 blade turbine for a light weight 9 blade turbine.
from my knowledge the new turbo spooled 200rpms faster, and he made the same power with 3-4 less psi of boost pressure. Without any other changes, besides touching up the tune.
Im not sure there is a GTX (11 blade style) drop in wheel for that turbo, I’d have to check the KTS catalogue, but that 6 blade seems to work great. His 2G is full street car, on QTP’s and is consistent mid 10’s at 135+mph
The following 2 users liked this post by EvoIX89:
2006EvoIXer (Jul 6, 2019),
Thank you all for the replies and EvoIX89 for chipping in.
I been dealing with my local Garret distributor and rebuild center and they have confirmed they can definitely fit in a GTX3582R GEN-1 11 wheel style billet compressor with some light modification to the compressor housing and upgrading the journal bearing. Keeping the TD-06H turbine.
I would like to think that the spool with the GTX GEN-1 compressor wheel should somewhat spool the same if not slightly better then the GT3582R compressor wheel. I am just hopping it wont be laggier.
The current 6 blade GT3582R compressor wheel is rated around the 65 lb/min
The GTX3582R compressor wheel is rated around the 75 lb/min
Lets say the GT3582R compressor wheel does 400-HP at 21-PSI is it more then likely the GTX3582R will do 400-HP at 19/20-PSI?
Once again thank you for all you feedback.
Volcom86 (Jul 7, 2019)
